Boole fails
5412.8
Hello,
You can further reduce the ripple by rebuilding the construction curves with something like a tolerance of .001 prior to performing the Network command. The original is grey, Networked solid is orange, and the green solid had the Rebuild command run against the curves prior to the Network command.
Ripple 2
EDITED: 3 Feb 2025 by OSTEXO
