Hi Rudl, there is a mitering mechanism in MoI in Sweep, it's when you do a sweep of a profile around a one-rail path like so:
However, it's meant to be used on a regular path curve where there is at most 2 segments joining together at any single common juncture.
The way that sweep mitering works is by generating a longer extended piece which then has its ends trimmed off by a miter plane created at the juncture area.
For your case you could either do that same kind of approach that sweep takes internally where you would build a larger extende piece and then trim it to a common cutting plane and then join the pieces together, or possibly you could use the mitered sweep on your 3 branched one if you did half of a profile at a time and did 3 different paths.
