Hi Moritz,
> : If this would solve the problem - how can I do this especially for .3dm-files?
I'm not sure how it would be possible to do only for .3dm files, because MoI doesn't know whether you want to open a 3DM file in particular until _after_ you've already picked the file in the file dialog.
That's because the file open command MoI allows for opening several kinds of files, not just only 3DM files...
Do you mean something like make it pay attention to when you switch the "File type" dropdown and shift to different directories when you switch that between 3DM or other file types? That would probably require some kind of fairly elaborate customization of the file dialog...
I could do something where you could set the default location for the entire "Open" command, would that work?
