Hi Martin, sorry I still don't understand if you have followed _all_ of that previous advice or not.
Again, the details on what to do are here:
 http://moi3d.com/forum/index.php?webtag=MOI&msg=4643.2
Did you  Set Options > View > Mesh angle to a rough angle like 25 degrees and uncheck "Add detail to inflections".
Did you set [Mesh Export] ThreadLimit=1 in moi.ini ?
After doing those do you still run out of memory when doing the export where you were seeing running-out-of-memory problems?
If you are still seeing a problem at that point, what happens if you just select only roughly half of the model - you mention stuff about various styles, etc... - I'm not talking about selecting anything by styles, just simply drag a selection rectangle around roughly half the screen to approximately grab half of the objects and then export that.
When you do these steps, do you still run out of memory or does it export ok after doing these steps?
The first steps about setting the different options you only have to do one time.
The second step about doing a window select of roughly half your model takes only a couple of seconds to do and does not require elaborate scripts or reading through style lists or anything like that.
Please check if these steps solve the problem for you or not - there is no point on trying to cook up a fancy script to solve the problem if you can already solve it with these easy methods.
