space navigator
5391.6 In reply to 5391.5
"""""""What happens if you turn off object snaps and then do the simultaneous movement while """"""""""
That doesnt change anything. Empty viewport is fine. Add a sphere and issue is there. No need to be in command or picking type mode. Actually, going into a command, like drawing a curve, creates smooth movement!!! So I place a sphere and get buggard, then start a spline command, and get smooth (Although a little more laggy, which is expected and not some unusual amount)....
