Hi Brian, I've attached a plug-in command that can be used to measure angles.
Unzip and copy both files into the \commands folder and then there should be a new command named Angle available that you can set on a keyboard shortcut (I knew you know that, just mentioning for anyone else....)
I've only really quickly whipped it together so it probably should be tested a bit to make sure it works ok.
