Hi there, a quick script request that could be useful for quickly drawing to a grid then changing the grid size...
Here's how it would work
1. Shortcut
2. Draw a distance (using cline) or input unit
3. The grid interval change based on that distance
1b. Shortcut
2b. Input 0
3b. The grid reset to the default size
Is it possible to do it ?
It would allow for example to align parts on objects after an array (if there's like 1.35cm between each objects) then reset the grid to default one you have finished
shapenoid.com |
