Moi3D Anti_Aliasing turn off
5370.5 In reply to 5370.4
Hi cinema4d, thanks for the additional explanation!
I have to admit though, that I don't really see a problem there in the MoI screenshot.
There are actually cases where the anti-aliasing can help to see exact overlap where it is impossible to see it with a jagged aliased display - that's because the way anti-aliasing works the semi-transparent areas will get darker when they are drawn several times in the same spot. So a line that is actually made up of several lines stacked up exactly over top of one another will have an even thicker darker look to it with the anti-aliased display.
See here for an example - here one area has 5 smaller lines stacked up right on top of each other:
With an aliased display you would not be able to see that same kind of thickening at all.
It could be possible in the future to add an option for this but I'm sorry right now there is not anything set up for that.
