Noob help
5358.2 In reply to 5358.1
Hi Pete, delete your trim curve, then select the long edge from your trimmed object, now click sweep and use the two smaller outer edges of the trim as rails. You can now join the two objects and create a joined surface. The screen grab below shows how good a repair is done to the underlying mesh by selecting the option to export as OBJ. Hope this helps ya bud.
Martin
Size: 285.9 KB, Downloaded: 58 times, Dimensions: 1804x974px
