I need help with flow command.
5324.1
Hello Michael,
How are you? This is Rudy.
guys....\
I am tying to wrap around (flow around) a pattern to my external surface of ring (see file).
here is how I understand the procedure, but do not get the result.
1- I click flow command, select object to flow. Here I put the cursor on the corner of patter (marked in red). It highlights. Click done
2- Select "base curve or surface".
Here it is where it gets heird.... My ring here gets divided in two sections (see image2). WHY?
So , I click on the edge of my half-ring , it highlights, and it prmpt me again with a "select target surface near matching edge side" and I click on the edge of other half-ring (original edge matching pattern)
3- my pattern duplicates. If I mark "rigid" the straight, duplicated pattern mirrors. If I check "flip surface normal" it produces something......(see image 4)
What am I doing wrong. Why my ring get's divided in two sections?
Thank you for your time. I love MOI.
But I have so many things to learn......
can somebody explain me in details how this works?
Thank you.
Rudy
Size: 369.6 KB, Downloaded: 63 times, Dimensions: 1440x900px
Size: 339.7 KB, Downloaded: 43 times, Dimensions: 1440x900px
Size: 577.4 KB, Downloaded: 42 times, Dimensions: 1440x900px
Size: 652.4 KB, Downloaded: 61 times, Dimensions: 1440x900px
