Hi Arymond, the white glitch will probably go away if you maximize the MoI window and leave it maximized when you close it down so that it will start up maximized initially when launched.
Have you tried the IE Reset button that I've mentioned previously yet? You're probably running into some mangled registry settings from whatever registry cleanup that you did. Doing the IE reset may help solve that.
