MoI3d 1.1 Glitch/Broke!
5318.6 In reply to 5318.5
Hi Arymond,
> Dose it matter that i have IE9?
No, that should be ok, there is a cosmetic glitch with IE9 where it can cause Moi to initially come up with a white screen and then it operates normally after that, but that does not seem to be what you are running into.
Either you've got some kind of IE add-ons that are not working right or something in your system registry has gotten mangled and that's preventing IE from functioning normally. If you use that reset button it will purge your registry (only the parts related to IE functions) and reset it all back to "factory defaults" so that may solve it if registry corruption was the particular problem that you were hitting.
