How to do this??
530.8 In reply to 530.7
Hi Slobodan, are you still stuck on making the bowl part, or on some other part?
Did you check out the sink_5 version attached above? Does that result look ok to you? I can give you some more detailed steps on how that was created if that would help.
It is difficult to put a good smooth surface using exactly the curves that you drew - to make it easier I changed the ends of your curves to come down straight at the bottom instead of having a tight curve at the bottom, then used a fillet (with blend style shape) to produce the rounded bottom.
If you are still getting stuck with this approach, please post another model file of where you're at.
