Hey Michael & Danny,
Thank you for your kind words about my close to first creation ... And not least also for helping with my questions ;-)
@Danny: A bit surprising that it has this volume :-( It's supposed to be about 111 millimeters high, about 73 mms wide and 3 mms thick at the thickest point. That shouldn't give 8368 cm3 - I hope as it's likely to be cast in silver .... ;-) Hmmm... I just noticed that the scale wasn't set to millimeters so guess that does it ...? My guess is that the volume is 8.363 cm3 meaning that the weight will be about 85 grams. Could that be right?
It's interesting also that you found that one half of the model was not a solid. When modeling it I first "unioned" the upper part of the model and the rods and frame appeared to join completely, whereas when I did exactly the same to the bottom half then some ellipses remained on the outside of the frame. I reckon this is why one half (bottom?) was not a solid. How do you see this, by the way?
@Michael: Thanks for the link to ViaCad. I don't know if this is the place to ask for this - but since I'm currently evaluating some CAD softwares (& somewhat "steaming" beyond what the summer brings about from so doing) do you then have some comments about the difference between ViaCad & MoI3D? Maybe a thread somewhere?
Thanks for reading & maybe replying ;-)
Jesper
