Projecting splines
5268.3 In reply to 5268.2
The intersect script shows all of the intersections.
Here is a procedure to do the trimming:
Select base plane, color it green, and hide it, or just delete it.
Run the intersect script, which shows the intersection points. Color them red, and hide them.
Select all of the lines, and run the trim command, with Keep. Then select the red points as cut points.
EDITED: 21 Jul 2012 by BEMFARMER
Size: 149 KB, Downloaded: 42 times, Dimensions: 790x373px
