Moving from Cut3D into Moi?
5255.7 In reply to 5255.5
Hi Tony, what method did you use to move the data into a 3DM file?
Probably what happened is that you have now created a 3DM file that only has polygon mesh type objects inside of it. MoI does not work with that kind of data at modeling time so it will just skip over those type of objects if they happen to be in the 3DM file that you were trying to import.
Again, polygon mesh data is a much different type of data than NURBS surface data. MoI is designed to work with NURBS surface data for modeling and is not set up to import polygon data. You can _export_ polygon data out from MoI but not really import it in.
If you need to edit polygon mesh data, you need to use a polygon mesh editing program to do that instead of MoI. You can look at something like Silo for example: http://www.nevercenter.com/silo/
MoI itself is not set up to edit that kind of triangle-mesh structured data, which is what it sounds like you're trying to do here.
