Closed curve edges to edge selections
5250.4 In reply to 5250.3
Thanks Michael.
So if I was to run the rebuild command now would that sort out this issue? Or would I have to go back and rebuild the curves first then run the rebuild command?
When I built the curves they were built from straight forward curves as the tut suggests and then joining and so on. How often is best to keep running the rebuild command whilst building this sort of stuff to avoid these problems?
Thanks again Michael for you help here.
Lang
