Closed curve edges to edge selections
5250.1
Hi all
I'm just in the process of going through the tutorial for building the speaker by Magic" Mike and have got to the part where I need to join the bottom circular edges with the outer frame. When I try and do this the bottom edge is a edge selection but the loft edge is a closed curve. If I delete this curve (which is one unit, how I like it) it leaves me with loads of parts to the bottom of the lofted outer part which is harder to select. Is there a way of getting my joined curve to work so I can blend the two edges together like in the tut? I sure its basic but I am still a beginner ;-)
Thanks guys and see attached.
Size: 676.2 KB, Downloaded: 91 times, Dimensions: 1698x826px
