WebGL and MoI.....Maybe?
5219.15 In reply to 5219.10
Hi adamio, have you been using it yet? Is it working well for you, have you actually used it to send information to someone else?
How does the editing part work - do you know if Sunglass takes actual CAD data like 3DM, STEP, or IGES files or does it only work with polygon data only?
> When I posted this my only thought was; It'll be cool to have a Web collaboration viewer
> for MoI, since Sunglass was releasing the API.
Ok, but can't you use MoI with it already? It seems to say that it has integration with Dropbox - does that mean that if you save a model file into a particular folder in Dropbox that it will auto upload that? If that's the case then just save from MoI into that one particular folder and then BAM! you're using MoI with Sunglass right there, aren't you?
What is it in particular that you hope to gain by a plug-in instead of that?
> Still not convinced about WebGL coolness ? Then I guess you have to click http://madebyevan.com/webgl-path-tracing/
That's definitely cool! Cool and useful are fairly different things though.
How is it going to work to use WebGL for a viewer when WebGL does not function at all on Internet Explorer or the iPad?
> Michael since they have a plugin Rhino do you think it maybe easier to cook one for MoI also?
Not really - MoI does not implement Rhino's plug-in interface, MoI only implements a file reader for reading the Rhino 3DM file format. File formats and plug-in APIs are pretty different things.
> Since 3D PDF export support is not likely to happen for MoI, that maybe a good alternative, NO?
It might be as long as you know the person receiving it does not use Internet Explorer.
I don't understand why you make it sound like you can't use MoI with it already though - can't you just upload files you generate from MoI using one of their general purpose file upload tools?
Why is it that you think that a special plug-in is required in order to just upload a file to their service?
