| 2) if you have made a boolean difference "surface" was be automatic ! No need to close curves etc... :)Never "Trim" a volume if you want surface! Always use the Boolean Diff between a volume and a curve/surface/curve !
 3) now you can can fillet the whole piece!
 but the open surface will be not filleted!
 you must close it before
 alas there not yet close function for close a general hole!
 You must make something like this : redraw a middle curve curvated, trim the edges with this new curve, Network etc...
 so the boolean Diff was indispensable for avoid all that !!! :)
