Problems with MERGE or TRIM commands
5212.2 In reply to 5212.1
Never mind!
I found a way to do what I wanted to do using the Boolean Diff command. I created a solid using those internal surfaces and the Planar command. Then I used the Diff command to subtract that solid from the middle of the larger piece.
I know you can create just about anything with MoI, if you just know the approach you should take.
Mark
