Getting a curve to follow a shape that tapers?
5208.3 In reply to 5208.1
Also you may want to run the Rebuild command on your initial curves before revolving them to make your cap, that will remove the segmentation from your generator curves where the segments were smooth to one another and that will make the cap made up of bigger surface pieces instead of split at every segment of your original profile curves.
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
