shortcuts for aligningobjects
5184.6 In reply to 5184.5
Hi nos - I tested it and it was working ok over here.
Did you possibly only set up the shortcut keys that were listed but did not copy over the updated Align.js file as described above?
Because if you have the original version of Align you would get the behavior you are describing - you need to update the Align.js file before those shortcut keys with the parameters in them will work.
