Question about a hub transition
5174.6 In reply to 5174.4
> It was in the file I used to get the style colors.
I see - so yeah that original file had some annotation text in it and the "round trip" mechanism that tries to preserve those kind of entities that MoI does not itself handle directly preserved it when you then save it out from MoI.
If you want to purge it, create some objects on the styles that you want to keep and then select those objects and use a File > Export to write them to a 3DM file - when you do a File > Export (which only writes the selected objects to the file and not everything) rather than "Save As", it won't do that round-trip saving of internally held entities.
File > Export does only write out the styles that are actually being used by the objects being written though, so that's why you would need to set an object on each style that you wanted to come through.
