noob problem
5148.3 In reply to 5148.1
One tip is that if you can very slightly adjust the shapes of your curves right in the local area where they come together to be straight right in that local zone it could make it easier to intersect, also when the curves are straight right in that juncture spot then it is possible to slice them both with an angled plane instead of having to intersect them with each other.
