Model Area Size - How to set the model area to 97" by 49" with no zero areas
5126.5 In reply to 5126.1
Hi Gary - Try options and then select Grid. You may have to model with negative values until your model is complete, then do a select all and grab the lower left most end point, then drag everything over by that point it to the origin (0,0,0) then when you save or export all of the objects should be positive values.
Martin
