Model Area Size - How to set the model area to 97" by 49" with no zero areas
Frenchy Pilou (PILOU)
10 May 2012 (4 of 10)
5126.4
In reply to
5126.3
Just enable the Grid, Button Options
You can input some dimension to your grid but seems that is a Square grid so not efficient for your particular case
The normal grid by default will be sufficient ;)
As you draw only inside the positive quadrant
