Edge Selection Toggle
5118.8 In reply to 5118.7
Hi yakas,
> thanks, after trying out for a little while it seems to
> select edges connected to a surface and not the edges
> on the same plane. Any thoughts
You mean the "select loop" script that was posted about previously?
That script works by selecting all the edges along one trimming boundary, so yes it will select a loop of edges that belongs to one particular surface.
There is some more description of how it works here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
If you want to do some other kind of selection like select all edges on the same plane, that script will not do that particular task, unless they all belong to one single face.
Usually for selecting all things on one particular plane you just go to a side view and do a window select of the particular area you want to target - when you are viewing from the side it makes it easier to capture a specific planar level of curves within one selection window.
Do you have some particular situation where you're having a problem selecting things? If so can you please post the 3DM model file for it so I could take a look at your actual file, that may help me to give more specific advice.
