Hi southpaw,
> maybe 13'3.5" reads as 160' before clicked on.
This one looks like some kind of other bug, it's probably something from that originally "foot and inch" type display was only supported for units=feet, then later on having "foot and inch" type display was also supported for having units=inches as well but something is likely getting crossed there.
The rounding part will kick in if you enter 3'.5" it will display as 3' 1" in that little properties panel.
But yeah entering 13'3.5" and having the display 160' I can repeat here and that's some bug separate from the rounding.
.... After a bit of testing, it does appear to be specifically for units=inches with "foot & inches" type display - if you switch to units=feet it seems to work properly.
So I'll dig into that to look for the bug in the properties panel display when units = inches.
Like you saw already if you push open the panel the stuff on the edit size panel is actually correct though.
