Ctrl copies active
5087.1
Hi Michael, is it possible to have a moi.ini 'yes' / 'no' option for Ctrl copied objects to be active selected once copied. Example; if I select 10 closely spaced objects, do a Ctrl copy rotate where the newly created objects are on top of each other, it is sometimes hard to then select the newly created object. If these were active, instead of the originally selected, on duplication then this could be a good option.
Thanks...
