Illustrator import - Shapes to planar face option Suggestion
5065.2 In reply to 5065.1
Hi Marc - you can convert sets of planar shapes like that into faces with holes in them using the Construct > Planar command. Just select all the curves, the outer one and all inside hole curves all at the same time, then run Construct > Planar and it will build a result like you are describing for you.
