This is curious but probably a known issue. Or, it is me.
5051.5 In reply to 5051.4
Hi Leonard,
> Are you saying the history function, because I moved the
> plane, assumes that I do not want the curves therefore,
> they are to disappear or be deleted?
Only if you move it in such a way that the projection actually misses the plane and so does not produce any output objects at all.
If you do that it is the equivalent of deleting the objects.
