Sine wave between points
5043.4 In reply to 5043.2
Thanks for that. I have seen, and played with that script. But it's not really what I am after. Your script gives a sine between A and B, I want a sine where sin(A) == 0 && sin(B) == 0. A trim won't do that, and scaling a sine to A and B would change the wavelength.
Not sure to be able to name what I am after: Modeling probably, instead of technical drawing. I need to see the curves to be able to tell if they feel right. Hence, my slider with interactive update. Impossible to key in wavelength and amplitude, scale or trim, and repeat until it is Ok.
So instead of a script where I need to key in numbers until good, I was after a scripts that is always good with visual feedback.
Ditto
