Projection of point selections
5040.4 In reply to 5040.3
Hello Michael,
attached is an example file. A projection of a spline drawn in sideview (cyan) will not give good results neither on the forefoot nor on the other side. So what I would want here is just select some points and project one at a time. Also I´d like to be able to project just onto the surfaces that I can see (face me) since the projection on the hidden surfaces give unwanted results quite often requiring more handwork...
Maybe you can also give me advice on why the basic object (blue) can be done with MOI network command with the splines I imported from a rhino file (green) but not with the splines I created in MOI (orange)
RogurtHello Michael,
