TextAlongCrv ?
5036.7 In reply to 5036.6
Hey Martin,
Here's one that flows ok.. Notice I moved the orientation of the text and flow-from surface to be flat on the ground instead of vertical.. I think this makes it easier to get things oriented and the flow used to have an issue with the vertical setup... You can fool around with this setup and rotate/move the "from plane" and text to move the flow around.
