Sometimes if I have a situation like that I'll trim out the uncooperative section with a circle and blend
the ends, effectively creating a fillet...or in the case of a meandering curve that doesn't flow exactly right,
a nice transition where there was something that previously that needed some improvement.
Blend works only on open curves, so this would only work if you're dealing
with open curves or closed curves that can be separated.
-Jesse
