another little hint
5003.9 In reply to 5003.2
Hi Mike,
> And add maybe an extra "offset"-value field?
If you locate your object at some distance away from the path curve, then array curve will maintain that offset distance as it moves the object around the curve.
But if you want some more control over that it might be better to do an offset of the curve itself and then use the offset curve as the path - that can help to see more what is going on with the offset shape.
