Hi Mike,
> even after rebuilding that curve it won't blend.
Your curve was still made up of multiple segments after your rebuild because your segments were not all smooth with one another - it looks like you've got a maybe 5 or 10 degree sharp corner in it in the areas where you can see there were still multiple faces generated:
So you still have not eliminated segmentation in the profile curves before doing a loft.
You can use Rebuild again, with "# of points" mode and turn off "Keep corners" in order to force a smooth curve through those sharp corners that you've got, or you can turn on control points and delete the control point at the sharp juncture to make it smooth.
