Yeah usually you would also use a boolean for that - finish building any pieces of your curved surface so that it is a solid volume and not just a single surface and then create your text as solids. Then select your base piece and run boolean difference, and then select the text as the cutting objects and it will cut into it and leave an engraved result.
But how would the text follow the curved surface?
MIke
