please, need help again!
4997.18 In reply to 4997.16
Hi Mike,
> But what, if I'm building up and the work goes further and
> further and then later (maybe too late) I decite, that I want
> to add an extra shape or part somewhere.
> How do I manage that?
Well, a lot of these tips here in this thread are about how to do things better for filleting.
Do you mean that you would decide to add another part to the object after you have done some filleting on it or before you did the filleting?
If you wanted to do it after filleting, then you may have to reconstruct that area of the object. But it depends on the particular case.
If you think you might add more parts to an object later, it would probably be better to use the "more segmented" type approach where you had things more separated out so that stuff like planar areas of your shape was one separate plane surface instead of it all as one big single surface. That approach would lend itself better to adding more pieces later.
> Does it mean, that I (better) have to rebuild the
> whole object at the end?
It could mean that but it depends on the particular situation...
