Auto focus?
4983.2 In reply to 4983.1
Hi ed,
> I know if i press the minus sign before the numeric value
> when a tool is active, it doesn't work in the 2.0 version (or
> older), i don't know if this is a feature or a bug.
Have you possibly set a keyboard shortcut for the - key?
If I remember right in earlier versions that would then interfere with numeric entry.
> A lot of times when I'm working on the 2.5 mac version,
> I press tab with no tool active but the
> coordinate-field/command-bar is not highlighted and
> I cannot write commands.
I can't seem to repeat this happening over here... Let me know if you figure out a particular thing that triggers it, like if some particular UI that shows a dialog or something like that gets it into that state afterwards.
Also when you run into it, if you do a single click somewhere on the MoI window does that then fix it?
