3d Shrink Command (3d Offset)
4974.3 In reply to 4974.1
Hi NightCabbage - it looks like it is similar enough to Inset that it could be possible to have it actually handled by Inset rather than as a separate command?
It is possible in inset to control the border thickness separately from the inset depth, by checking the "Use separate height" option.
So I think what you would want would be to have a 0 sized thickness for the border but then set "Use separate height" and specify a non-zero height/inset depth type value, is that correct?
Right now I think that it does not think that a zero thickness is a valid value and just bails out, but would that combination of 0 thickness + "Use separate height" height set give you the result you are looking for there?
