In Turbocad, you can change a solid to a surface, and in most instances a surface into a solid, only problem is when you convert a solid to a surface, it has faceted sides, and if you the change it back to a solid, you end up with a solid with faceted sides. The big advantages in cad would be a surface or SMesh representation of a solid, which would require far less memory to manipulate.
