Hi ed17,
You could use array/curve if you want a defined distance.
Just draw a Line or a Curve and place a Point object at the startpoint and then type the distance.
The Point objects drawn can be used as snapping objects.
Often i use a circle or sfere object intersecting with a line in 3D space to find the right snapping point.
It is like using the classic compass when drawing on paper.
