Hi Sebastian,
> And I can't break it up 'cos MoI always gives up the ghost.
To split it up into smaller files, try selecting some objects (like maybe just half is fine) and then write only those objects to a new file using File > Export. Then don't delete them since that will create a huge undo unit - instead use Select > Invert to flip the selection around and then do another export.
That should help to break the file down into 2 separate files.
