And attached here is an edited version which should trim ok now.
I edited the curve by turning on control points and using the Transform > Move command to move the endpoints together and then deleted the ending point to make it a smooth juncture there.
You should now be able to use it as a cutting curve directly with Trim like Danny says you don't need to do a separate project step.
