Fillet
4928.10 In reply to 4928.9
Hi Tony,
> I can not explain this thing
I'm sorry I don't understand what this part means - are you still having a problem with the fillet?
You should be able to fillet the file you posted as long as you do not use a radius of larger than 0.02 units. There is not enough space in the thin areas of your model to fit a fillet any larger than that.
