stuck with revolve
Select the rectangle as profil (Preselection)
Call Revolve
Select axis with 2 clicks start / end (start midle of the circle, end anywhere in the space but vertical, z must be writed as help text if snaps enabled )
edit (I had said select circle here but of course no need :)
That all (if I good understand that you want :)
EDITED: 13 Feb 2012 by PILOU
