Hi Pilou - you can use the Flow command to get something close to that - draw a line under your original "12345" and then use that as the base curve for Flow.
Then there is a "Rigid" option in Flow which will only move and rotate the objects instead of actually deforming them.
The objects will rotate to follow the path though, which is the one thing that does not match what it looks like you want.
