@Mip: No, I did not use any special importer script. I simply export as OBJ. I usually leave the default settings except for:
uncheck "Weld vertices"
I DO play with "Divide larger than:" and "Avoid smaller than:" to get the resolution that I want.
In Blender, use the set smooth option for objects to avoid seeing faceting in your render.
